j-d
Jul 02, 2018Explorer II
DiskDoctr wrote:
...when it goes, it throws junk into the transmission ...If you're not a "transmission guy" (I'm not), either find one or commit to replacing transmission, torque converter and cooler...
This is what I've always heard. Failure of transmission or converter contaminates the other, and the cooler as well, but I'm not a transmission guy either.
You had a gripe that the engine was running warm, and some speculated the converter might not be locking when it should. Slippage causing heat. I wonder if converter WAS failing, one symptom being failure to lock, and it got worse to where it finally scattered. But I'm not a transmission guy...
38,769 PostsLatest Activity: Apr 24, 2002
