SCADAMAN29325's avatar
SCADAMAN29325
Explorer II
Oct 24, 2022
My generator may not be repairable, what do I do?
I thought there was a generator forum, but could not find it...
My generator is an Onan 1984 3600 KF (LP) and I cannot find the part for it ((Gen thread)). And a new is like $4000. How do I go about making this one to work? this one
Also, it's too big to go back into the same compartment. I was thinking of getting a cargo hitch. and then plug the RV into it's 30amp socket.
Newbie here with a steep learning curve ahead of me.
  • Regarding the replacement generator.
    Check to see if the "compartment" is an actual compartment or if the floor is nothing but the base (part of) the exiting generator. If so, check to see how much below the existing generator the new one will hang once you make your own bracket and shelf.
    Go examine the proposed generator and see how much height is taken up by the base and wheels. If mounting inside the RV, there's no need for the wheels and base to be attached. You can keep those as a platform for if or when you remove the generator and want to roll it around.
    Next remove the side covers and see what is above the working portion. Often the top is just an integrated handle and fuel tank. If the handles can be removed or eliminated, you may gain another inch or so. The fuel tank may also be removed or relocated within the compartment if you can find a way to ensure fuel delivery.
    You should be able to connect the generator to RV just like the previous generator without he need for added or outside cables. If you want to keep that replacement generator intact as is, a cargo carrier setup is very common. Just know you'll have to do some creative cabling if you plan on using it while in motion.
  • For your house batteries question. Do you already have existing batteries and need to replace? Or is the battery compartment empty and you need to know what to put in there?
    If you have existing batteries I would first try to determine if you have 6 volt or 12 volt batteries.
    Hopefully the voltage is plainly marked on the batteries. But if not you can count the caps on top of the battery used for adding distilled water. Each cap is a 2 volt cell. So 3 caps per battery = 6 volts and 6 caps per battery = 12 volts.
    For replacement batteries (both 6 and 12 volt) I find the best prices at Costco.
