calfman47's avatar
calfman47
My headlights went out lowbeams and highbeams.
Both high and low beams just went out all my other lights work fine.
I cut the wires to the low high bulbs and added a switch and fuse and they are working now while i have them on seperet circits.
I have no power to the two origenal light power wires.
Someone told me it was the headlight relay which I cant find, I think I coud fix it if i could find it.
If anyone can help it would very much apprecated.
2002 damon intruder 8.1 workhorse chassis.
  • Probably a headlight switch - there's no fuse for the headlights, they use a breaker.
  • eHoefler wrote:
    Did you check the fuse?? Also, check the headlight switch and the dimmer switch.
    x2. I smell a bad headlight switch.
  • Did you check the fuse?? Also, check the headlight switch and the dimmer switch.
