booster
Aug 10, 2014Explorer
wincrasher65 wrote:
I take it that draw is somewhat regulated by what is plugged into it, yes? So if you are only using a usb port for the 2 amp, then you have those 2 amps plus whatever it takes to power the inverter?
yep, that is the way it works, but if you only wire it for 15 amps, you might as well use 100 watt inverter so nobody can plug in something too big and start a fire.
38,782 PostsLatest Activity: Sep 10, 2026
