2008 Winnebago Journey 39z I picked this motor home up a couple weeks ago now. Been going through everything making sure all is up to snuff. Bulbs, clean up etc Upon investigating the battery co...
The ohm symbol , the Greek letter Omega represents resistance You want to measure resistance, aka a continuity check To see if the wire is connected directly to ground, almost zero only a few ohms resistance Or whether you are reading thru a device
