bedpan's avatar
bedpan
Explorer II
Jul 28, 2019
Mystery Wires... Any thoughts?
Hey folks,
Was climbing around underneath doing some clean up and prepping for a trip on our trailer and found 2 mystery wires. I am trying to figure out what they are used for. As best I can guess they are grounds, but the placement just does not make sense.
The trailer in question is a s 2018 Sundance 241BH.
Two wired floating next to the frame with Lug ends on them on the passenger side near the rear tire. There is a bit of a bolt sticking out that I wonder if they are suppose to be bolted to for ground. Tracing the wires back they wrap around the frame then go up through the floor into the area of the fuse panel, furnace and fridge.
Next time I am out working I will try and figure out how to access that area from the inside of the trailer and trace them out.
Any thoughts in the mean time?
Click For Full-Size Image.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
