TNGW1500SE wrote:
"If it ain't broke, don't fix it"
It everything works why attach it? I'd trace it.
On a motor home there are some systems that are "Always HOT" if this wire runs to one of 'em then it will meter exactly as you observed.
As TNGW said. if everything works, Do nothing
IF one circuit does not work Here is a SAFE way to apply power to that lead Method 1 and 2. 1 is for low current draw loads. 2 for big ones
Go to Auto-parts store (if you don't have one) and get a 12 volt Ice Pick.. Well Test light. this looks like an old fashion ice pick with a wire coming out the handle and a light bulb inside the clear or translucent handle. Hook the clip to the wire under discussion and touch the battery plus. BRIGHT light indicates you may need a bigger lamp.. DIM good. start looking for something that did not work that makes it bright.
Method 2: Use a bigger bulb.. Like a head light from a garden tractor. Or a 100 watt (my favorite) 12 volt Trouble Light.
This is a standard looking light bulb, like a 100 watt screw in 120 volt lamp. but it's 12 volts. the "Drop light" has battery clips where the plug belongs. Have also seen one with a standard plug and an outlet with battery clips
Don't want to invest in teh entire 12 volt trouble light?
A tunnel light socket and a couple of battery clips and the 12 volt bulb.
