darsben
Jul 22, 2014Explorer II
MountainAir05 wrote:
On most the gen set overrides the shore power.
I think the opposite ! On mine the Shore power overrides the genny. If the switch in your home senses shore power it will use shore power.
My thought is to switch the fridge manually to propane/gas and then unplug the shore power. Conduct the a/c test then replug the shore power and put fridge back on automatic. Run the genny with just the fans running on the a/c for a little while just to make sure everything is functioning well on genny then load up each a/c one at a time. Check for surging of the genny after turning each one to a/c. I have a feeling the genny has not been used in a while.
38,764 PostsLatest Activity: Dec 23, 2025
