Trackrig's avatar
Trackrig
Explorer II
Mar 26, 2017
Need a small 12VDC heater
I have a 2005 Fleetwood Excursion 39S DP with good front air conditioning and heat. Having said that, there's a cold spot under the dash where my feet are so I'm looking for a small 12VDC heater to mount under there for use while driving.
I've looked at the heater hoses and they would be a pain to reroute. I have sufficient extra 12V power under the dash and there's lots of open fuses.
I've been searching the internet for 12V heaters and not finding anything that looks good. In reading Amazon reviews, nothing has looked good there either, though a lot of the reviewers had unrealistic expectations such as heating large vehicles during the middle of winter.
If you can recommend a small 12VDC, my feet would appreciate it.
Bill
  • 12V heaters would be too high amp to be practical.
    Check for outside entry or reposition floor duct.
  • I strongly recommend doing a good search for air leaks in that area first.
    When in heater mode, the heat should be blowing down near the floor near your feet. If it is not, there may be a problem with the ducting dampers.
    To get a good amount of heat from 12 volts, the current is too high for "standard" wiring and sockets.
