ronfisherman
May 12, 2014Moderator
I would replace your original batteries with a pair from Costco. Best return for your money.
I helped a friend with same unit as yours. Found that Jayco had mounted the Charge Wizard on top of the PD9180 converter. PD says to never do this. Putting on top of converter can cause converter to improperly charge batteries. Check yours out. Move it at least 12" away from convert.
Converter was also mounted on top of carpet. Cutting off air circulation. Put spacers under converter to help with cooling.
38,769 PostsLatest Activity: Mar 31, 2026
