SJ-Chris's avatar
SJ-Chris
Explorer II
Jan 19, 2018
Need help fixing captain chair arm rest (or replacement)
The passenger side left arm rest on my 2006 Four Winds Chateau 31P is broken. This is the arm rest that the front passenger can rest their left arm on or they can swivel it ~90 degrees up so that it's out of the way.
The arm rest metal post that gets inserted into the seatback has broken off at its base (but I still have it). Perhaps it could be welded back on, but the metal bracket inside the arm rest is difficult to get at and it might require removing all the arm rest material and maybe even dismantling it further. Attached are a couple of photos.
Has anyone had any experience fixing/replacing a captain chair arm rest? I looked under and around both captains chairs and I cannot see any tags or markings as to who made these chairs, so I cannot contact the manufacturer of the chairs. I will attached a photo of the chairs later in case any of you pros can identify them by sight!
I would love to find a place that sells replacement arm rests and just swap in a new one (or perhaps get two so they at least match). Does anyone know of any place that sells arm rests like these? I've googled up and down and called several places but cannot find any.
Thanks for your help!
https://imgur.com/2g7FJqE
https://imgur.com/2kZObCS
Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM TECHNICAL SUPPORT
No RepliesBe the first to reply
