n4hwl
Oct 15, 2013Explorer
The left rear turn signal is amber in color and separate from the running lights that are red. The left front turn signal is working fine . This is a Freightliner chassis. Today I plan on checking the ground connection at the connector to see if it is good. If not I will run a good one from that connector to ground and see if that does the trick. If the ground is good I will check the positive wire at the connector and run a new one to that one if necessary. If both are not working I will run 2 new wired to the fixture and see if that works. I will report later today on my progress.
Thanks for the suggestions
Ken
Ken
38,783 PostsLatest Activity: Sep 22, 2026
