prism
Oct 15, 2013Explorer
n4hwl wrote:
Also I am planning on calling Tiffin this morning before I start the above process. A fuse would be a lot easier to fix than running new wires ..
We will see
Ken
Did you check to see if there is a fuse and a relay same as my 2008 bus has?? Like I told u there is a fuse and a relay for each flasher at the rear of my 08 bus.Now your unit being older and using seperate turn and brake lites may be wired differently
you indicated you had no power at the source?and now your talking new ground wire maybe? what ground did u use to check your 12v power at the lite? YOU MAY WANT TO try what aorevious poster has suggested and start at the TS switch and see what kind of out powers your getting
also do your hazards flash??? if so that rules out wires and grounds
38,783 PostsLatest Activity: Sep 22, 2026
