msmith1199 wrote:
I can't help you as I'm no slide expert, but my guess is it's simply out of adjustment someplace. The mechanisms closing the slide are on the bottom. So if they have pulled the bottom tight, and the top is still out, there is simply no way the top is going to close. My slide as it comes in starts to tilt inward and the top contacts first maybe an inch or two before the bottom. Then the mechanism pulls the bottom in and this causes a tight seal at the top. You say you have adjusted the slide up and down, but is there some type of tilt adjustment on the slide?
I would agree. I had my slide go out of alignment. took it to the dealer and took about 15 minutes to realign. The process is something like, unhook the slide motors, get it square, send some voltage across the motors to reset, and plug the motors back in. Worked like a charm.
