synergy_58's avatar
synergy_58
Need more water!
I have a 2009 Navion. The water tank holds 35 gallons, which seems to always be about 5-7 gallons short during 3-4 day weekend trips. How can I increase my water storage? Is there a way to add more water to the current tank, without undocking and heading to the closest water source?
Ideas anyone?
  • rockhillmanor wrote:
    The best place to find RV and Truck camping water tanks is off a horse trailer website!
    They make great corner fit water tanks that fit real nice in a toy hauler and inside an RV. And real nice flat ones for the back of a truck.
    This is the one I use in my horse trailer and then take it out and put it in my MH when RV'ing when I will need additional water once I arrive at my destination. I fill it up when I get there before parking the coach. Will hold 25 gallons. The best feature is where the water comes out so you don't have to use a hose.
    http://www.horseloversoutlet.com/25_Gallon_Slant_Load_Stand_p/ftc-slst.htm
    To see all of the different ones available go here and scroll down to bottom.
    http://www.horseloversoutlet.com/Water_Tanks_for_Truck_Trailer_s/60.htm
    Interesting. The tanks seem well built. I'd like to be able to install a tank connected to my main tank, so I won't have to fill jugs and lug them around.
    I read of someone installing an external fill connector to the main tank so they could pour directly into the main tank from a jug, without having to move the RV, but I can't seem to locate the post.
  • There are a number of ways to store extra water. However perhaps you can figure out ways to not use as much. A little less for each thing helps. Also always remember there is 6 gallons or so in the water heater unless you have an instant on. We have often put it on bypass and used a drain hose setup I made to get that water and add to the water tank. Just be sure not to turn the hot water tank on. Where there is a will, there is a way.
  • We just use plastic gallon jogs for extra water for cooking and coffee. We store them under the dinette seats.
  • The best place to find RV and Truck camping water tanks is off a horse trailer website!
  • We've always carried extra water in a container for coffee, drinking water and other uses that don't require the water in the tank. Washing dishes once or twice a day can also save water.
    It takes time, but you can learn to use less than 6 gallons a day if frugal.
