dshinnick's avatar
dshinnick
Need opinions, please.
Flew 800 miles to check out a 2012 Itasca Sunstar 30T; identical to Winnebago Vista 30T. 22,000 miles, 6 (yes, 6) hours on the generator.
I've had numerous issues pop up ever since I looked at this thing since yesterday. Condition is excellent; little things just keep going wrong. Not sure if I"m losing confidence in it or not.
My two questions:
1. Even though the coach has a transfer switch (Parallax ATS301), apparently it didn't do its job, and when the coach had the gen running while plugged into shore power, an excess of power was sent to the coach, and blew the inverter. As a result, when the gen runs now (which it does well), there is no power sent to the coach. In fact, one mechanic said that when he tested it, half the inside coach outlets get power, half got none, and there was no 12v at all. Different mechanic says the inverter must be operational for any power to get from the generator into the coach itself. Does this sound right?
2. We've flushed the water system a few times to clear out the winterizing that the previous owner did. Then filled the water tank, disconnected the water hose, turned on the pump, and ran the water to clear out the air. I then turned on both gas and electric water heaters and left it alone for an hour. When I turn on the hot water, at either of two sinks, I get hot water for a few moments, then cold, then hot, then cold, then hot, then cold.....and it just keeps cycling. The water is running continuously, there's no break in the water stream. Never seen that before. Any thoughts?
And, if anyone has any experience with the Winnebago/Vista line, or Itasca/Sunstar line, I'd be interested in that as well. Trying to decide whether to keep giving this guy another chance...it's gorgeous interior and all-around excellent-appearing condition....or to call it a day and walk.
Thoughts? Advice?
Thanks-
dave
