Arrived last evening at RV resort leveled the coach, went to open slides they moved very slowly and stopped about two inches from being fully open won't come back in either will only move one inch in ...
Hard to troubleshoot unless we knew what sort of slides they are. Mine will run slowly if the batts are low as they are electric. If I plug into shore power they work much better as I can't deploy my slides if the engine is running. I can if the gen is though. Anyway, if yours are electric is sounds like a power issue.
