dpfitch's avatar
dpfitch
Need some help with Coolant issue in 2002 Tiffin Allegro
Bought this bus in June of 2015 in Phoenix. We live in Twin Cities of Minnesota. No problems with bus this year. It was a good buy.
Putting storage cover on bus last week and it dawned on me that checking the coolant protection for low temps was something that I needed to do. The engine radiator coolant is only good down to zero F which is not good here in the land of subzero temps.
I have, without success, tried to determine what to do to add coolant into system to get it down to -35 to -40. I read that I need to remove lower radiator hose to drain the system and honestly I don't know what I am looking for. I am not a neophyte around car engines but this diesel engine (Cat 330 HP model 3126) and the radiator don't look at all familiar. The only possibility is a hose into the the back of the radiator housing about 8 inches above the bottom of the radiator that goes down into a a rectangular stainless steel box that has a how on the other end that looks like it goes to the engine.
My Goal is not to flush out the whole system, that can be done next spring. I just want to get enough non diluted antifreeze into the system to prevent freeze up this winter.
HELP! THANK YOU.
David
Here are some pictures they are in order
http://screencast.com/t/a6veAx2f
http://screencast.com/t/HnltNvEdL
http://screencast.com/t/xtlbNfJsqh4
