dcason
May 14, 2019Explorer II
Need suggestions....flooring!
Since we have a traveling dog and had been using carpet protector over our clean carpet in our small class c (24 foot and NO slides), we have decided to pull the carpet which is in some curved design under the dinette. We asked on here and it made sense that the linoleum would be under the whole floor (not cab area).
Hubby pulled the carpet and found: The linoleum stops about 2 feet from the cab area AND the plywood subfloor where it meets with another piece is not even close to being level. The piece that goes to the rear of the rv is about 3/32" higher than the front piece.
So we could put floor leveler on the piece of plywood that is not high enough and slope it. It is located about 2.5 feet from the step into the cab...what were they thinking?
I've read the flooring posts on this forum. The easiest thing to do but not the prettiest is to add in another vinyl flooring piece to make up the lost space and put down an ugly metal strip to connect the seam. I would be fine with one continous piece of vinyl but I think that would involve a tyvex pattern (so it would not rip) and cut it 1/2 larger all around....BUT there is no room under our lower cabinet doors to put quarter round.
Any ideas? Hope floor plan goes through?
Here is our floor plan...as you can see pretty much nothing is straight.
jayco 2005 escapade yslp
