mist4life's avatar
mist4life
Need your experience
I just inherited a 2000 Fleetwood Bounder 34D with a Ford F550 chassis with V10 engine, that has been sitting on concrete in a campground for 10+ years. I have installed a new fuel pump and it started and we rejoiced. It needed all 6 tires and a local company came in & installed the front two and drove it back to the shop to install the other 4 and to check out the engine. This is not a company that we are familiar with but we had to read reviews and get some feedback from the locals because the rig is 4 hours away from us. We just want to get it road worthy so that we can bring it home and get our local guy to check it out. Here is the issue. We were told Friday that it was ready to be picked up, running great and the new tires installed and balanced. The bill was $4500. They changed fluids, belts and vacuum lines, also checking out the brakes, lines wiring. They wanted to install a new battery ($340) and a tune up ($350), which we told them that we would take care of ourselves. They also said that it would need brakes in the near future. There is 6000 miles on it. They raved about the shape of the rig and what great shape it was in, how great it was running, etc.
Last evening we made the trip over, with the plan of bringing her home. We got up at 4 am to get on the road in hopes of beating the traffic. We arrived at the lot to find it unlocked. Not real happy about that but got in, started it up and prepared to journey. Our journey lasted a little over 2 miles. At 40, it started shaking really bad and I couldn't tell if it was the front or the back. It just stopped running and the battery was dead. Fortunately, we were able to pull into a mobile home park that had a gravel area to the side at the front and get it off the road. Nothing opened until 8, so we ran in and got a battery first thing, installed it and it started right up. As soon as I put my foot on the brake, it would stop running. The trailer brake assist pump (?) was coming on with the key on and staying on. Is this normal? Not sure what is going on but should sure use some of your collective wisdom. We were able to limp it back to the shop lot, without using the brake, where it died and would not restart.
We just feel really uneasy and at the mercy of this garage. There is no way that they could have driven and not get that vibration for one thing, and how could they say it was running great again, without driving it? Please share any thoughts or advice that you may have. They will not discover it until Tuesday, when the shop reopens, though we did call and leave a message, explaining that we were stranded and what had happened.
We're tired and disappointed and a whole lot lighter in the pockets for sure. We appreciate your feedback.
  • mist4life wrote:
    All the filters are new and have been changed. New gas as well. A mechanic friend mentioned an idle control valve but we have no idea. Just feeling really disappointed and a little discouraged. The tires were almost $3000 of the bill.
    Dont get too discouraged yet, with them changing all the vacuum hoses, theres a good chance one was mis routed or pulled loose. And as I mentioned before, an OBDII tester may identify your problem, If you arent familar with them google it, they plug in under your dash and read all the diagnostic data on how your unit was functioning. In 2000 they werent as complete as the data that is saved today, but they did monitor quite a few systems, and they can save you a ton of money if you know the cause of the problem you can cut back the chances of being misled by an unscrupulous shop.
  • All the filters are new and have been changed. New gas as well. A mechanic friend mentioned an idle control valve but we have no idea. Just feeling really disappointed and a little discouraged. The tires were almost $3000 of the bill.
  • If you just inherited it you probably don't have any money invested in it donate the 18 yearold head ache to the shop for the $4500 they put in it walk away and dont look back.
  • First change the fuel filter and drain the gas tank. Ten year old gas is no good. If the filter is clogged it may run OK at low speed, but not when the engine needs more gas.
  • What your describing reminds me of a stuck choke. Runs good cold, stutters and then dies when warmed up. Did you let it sit long enough to cool down and try restarting?
    I know things have changed drastically with the computerized control systems, but it just reminded me of that.
    Edit add on, Since you are there and the shop wont reopen till Tuesday, go to a local auto parts store and rent if you can or buy if you must a OBDII code reader to find out what the computer thinks the problem is. The units have come down in price to under $100 and can be used on any vehicle built since 1996.
