ndrorder
Sep 12, 2020Explorer
Unless you have an inverter which uses 12v battery to make 120V plug power, the two are separate and having something plugged in will not affect the battery. If you do Have an inverter, the plugs would stay powered when shore power and the generator off. Doesn't sound like that is the case.
If only using lights and water pump, those shouldn't drain a battery that much that 3 to 4 hours of generator can't replenish.
38,782 PostsLatest Activity: Sep 01, 2026
