Woodsie8_
Sep 12, 2020Explorer
Woodsie8* wrote:ndrorder wrote:
Unless you have an inverter which uses 12v battery to make 120V plug power, the two are separate and having something plugged in will not affect the battery. If you do Have an inverter, the plugs would stay powered when shore power and the generator off. Doesn't sound like that is the case.
If only using lights and water pump, those shouldn't drain a battery that much that 3 to 4 hours of generator can't replenish.
I think I have an inverter.
I usually have the RV plugged into shore power and it charges the house battery. I guess when I get electricity back, I will plug in and see if the house battery charges. I also will see (once charged and unplugged to shore power) if the outside outlets are alive. It lasted for 3 days, so it had juice, assuming from the generator keeping it charged. A deep freeze and house frig probably pulls a lot, and I used A/C a very small bit, with inside lights and water pump for toilet.
38,782 PostsLatest Activity: Sep 01, 2026
