MrWizard
May 11, 2014Moderator
According to this website
http://www.tripplite.com/sku/RV750ULHW/
It is a combo inverter & charger and has a selectable charge rate, either 11 amps or 45 amps, selectable using DIP switches
Find the manual, and check the switch setting for the charge rate
Other switches control over voltage protection, where shore power is disconnected and inverter turns on, this will only be for circuits that are using the inverter circuit, most likely the entertainment circuits and some 120v residential lighting
38,769 PostsLatest Activity: Mar 29, 2026
