PinkLeopard's avatar
PinkLeopard
New 6v house batteries & main battery losing charge
Replaced 2-6 volt house batteries because they weren't holding a charge. Immediately afterwards voltage dropped rapidly to about 12.8. Checked water - it's ok. Charged with generator and shore power to 13.6 but they're not holding a charge.
  • Aren't you supposed to be able to charge them up to 14+ and when it shows around 12.5 you're supposed to charge them.
  • It's my understanding that when batteries are at rest with no load and not being charged 12.8v is a normal voltage level. However if when batteries are at rest with no load and the voltage drops below 12v then you have a problem..
    Good luck & safe travels...:)
  • discount ground cable and re-charge with a regular charger. After the battery shows fully charge remove charger. Wait 4/6 hours and check voltage again. Post back.
  • Hi Debbie & Bill,
    Can you describe what's happening a little bit more? Because from what you're saying, things sound OK. A fully-charged battery bank would show 12.8 (assuming there weren't any loads on it).
