wolfe10
Jan 19, 2015Explorer
The Caterpillar C7 very likely has two belts:
An old fashion V belt that drives only the water pump. So, crankshaft pulley, water pump and manually adjusted idler pulley. THIS BELT IS CRITICAL-- if loose, the water pump may not turn and engine will overheat. It can only be checked from below-- driver's side of engine between block and fan shroud. It doesn't need to be bar tight, but should not be loose.
The other belt is a serpentine belt which drives the accessories. So, crankshaft pulley, alternator, A/C compressor and automatic belt tensioner.
Here is a good video on belt tensioners from Gates Corp: https://www.youtube.com/watch?v=uTLV5IU_IMM
