supercub wrote:
I have an 04 DP on a Freightliner Chassis with 42,000 miles. Cummins 8.3 350hp engine. In the last year, I had to replace a lift pump and the ECM. Other then that, everything runs and works great. Personally I'd lean towards the Diesel Pusher. Good luck
Brian
I have a 14 gasser on a Ford chassis with 34,000 miles (purchased new) with a Ford V10. In the last two years we have changed the oil. We fulltime in it and have been from Alaska to Florida.
We looked at DPs because we full time and put in a lot of miles. But, we just couldn't find a DP in the size we wanted (under 35') that had a layout we could live with. In the end, we realized that we drive a lot less than we park and enjoying our bus when we are parked is a heck of a lot more important than if the engine is quiet when we drive.
Effy is right - find a floor plan you love. Make sure the bed is comfortable, the seating arrangement works, you have enough kitchen counter space, the storage will hold what you need, and the shower is tall enough. If you don't like living in it, you won't drive it anywhere anyway.
