Old-Biscuit
Jun 01, 2014Explorer III
Don't know why Dometic did away with the Climate Control Switch :H
The drain line needs to be positioned downward so small cup inside food section doesn't hold water. Cup should only collect water from drip pan and then direct it out into drain tube.
Tube should be positioned out the bottom vent cover and have a plug in end of it to keep critters etc out of tube.
Drain plug.......LINK
The 'thermistor'....is the temp sensor for the pre-set temp control.
The end of thermistor (bulb) should just stick out top of plastic clip and the clip is attached to the right side fin.....mid-position.
You can make minor adjustments to temp (6*-8*F) by moving the clip.
Moving it UP/Colder
Moving it DOWN/Warmer
After moving wait 24 hrs. to check results.
Moving it UP/Colder
38,766 PostsLatest Activity: Jan 10, 2026
