ncrowley
Apr 17, 2015Explorer II
Budget between $3K and 4K per year for maintenance and tire replacement. This assumes you have someone else do all the work. You can save money by doing what you can yourself. For example, it is not hard to change the air filter. Even if you have someone else do the work, you should know exactly what they should be doing so you can make sure everything is done correctly.
