retiredhfd's avatar
retiredhfd
New flooring question
We removed our old carpet and installed new wood flooring in our coach.I would like to remove the remaining carpet on the slide. My slide has a 2" metal edge covered with carpet that extends past the metal edge 3" to make the transition when the slide is open. Must I leave the carpet on or is there some way to do the wood flooring at the slides edge?
1 Reply
  • You will need a wood stair nose trim. See if you can find that in the accessories of the wood you just installed. A piece of plywood will need to be installed and brought inboard enough to cover the ramp
