RickLap
Jul 17, 2013Explorer
We just did the laminate and let if float. We looked at tile, but the only flexible grout you had to mix yourself. If you have slides and do the laminate, be sure to bring the slide in slowly before you place your last strip. there are "L" shaped beams on each end of the slide that may hook the laminate when the slide is brought in. You have to make sure you give yourself clearance or you'll tear up the entire floor.
38,778 PostsLatest Activity: Jun 04, 2026
