Executive45
Jan 14, 2019Explorer III
js218 wrote:
At Norton pond,have 5 acres on the lake with full hookups for the rig plus a cabin love the snow
Jim
You guys need to move your posts to "Around the Campfire" :)
To the OP. I have just shy of 100,000 miles on mine and have had no problems or issues with the engine. The mileage would not bother me but I'd recheck the hours on the genset. There is a mistake there-just how big of one, I dunno. That coach would have been top of the line for Monaco and in 03 they were still considered above average as a company. I'd book a cheap air fare and go see it in person. If I liked it, then I'd spring for the inspection. Things to check for are maintenance records and date codes on the tires. If the coach was serviced regularly, the dealer/facility that did the service should have records if the daughter does not. The date codes, most likely will be on the INSIDE of the tires so dress accordingly. Also, any Cummins facility can give you a readout on the engine if you give them the engine code. Look for a tag on the passenger side of the engine compartment. Finally, call Monaco, now RVI, @ 1-800-509-3417 and see if they still have the build sheet on that coach. If they do, they'll fax or email it to you. That will have all the serial numbers of everything on the coach...best of luck..Dennis
