donnyB7
Aug 21, 2017Explorer
New MH - battery drain question
I just bought a new MH, Winnebago Adventurer 35A. This is a gas MH and is my first trek into RVing. I have several questions, but will start with the most pressing. When I run my engine or my generator, I can press the volt meter on my control panel. The engine battery shows 13 volts. The house battery shows 13 volts (all plus or minus a few). If I shut off the engine or turn off the generator, the house battery shows zero and engine shows 13 volts. The batteries are brand new, but the house batteries (2 each) are dead. I have a dash switch labeled "battery boost" and a switch near the battery bank at the step labeled "auxiliary battery" on/off. I have never used batt boost because I am not sure what it does, and have turned aux batt switch to off when we park the MH at the storage place. Also, I have one solar panel on the roof that shows the house batteries are charging in sunlight, even when they are showing zero on the control panel. Any ideas what I am doing wrong?
