BruceMc
Dec 13, 2013Explorer III
chinrv wrote:
... They have E2 in a circle, with 2 rows of numbers in the date section: 04602 above 002603. I don't know if the info on the other side of the tires is different (dual wheels - can't see the other sides), but........buying all six tires at the same time, one should think the manufacturing dates would be close, and I can't figure out what or why the two rows of numbers mean. This E2 and the two rows of numbers do not appear on the front tires. Anyone else see this on their tires? ...
Mine are similar to yours; the Dot Sequence is on both sides. I also have the E2 in a circle and the set of numbers in a smaller size than the DOT sequence. The date code is 4 numbers, and it is the same size as the DOT Sequence (B3JH AKEX). The date code is only on one side... you'll need to pull the set of duals to see the date code.
