chinrv
Dec 13, 2013Explorer
Mine are similar to yours; the Dot Sequence is on both sides. I also have the E2 in a circle and the set of numbers in a smaller size than the DOT sequence. The date code is 4 numbers, and it is the same size as the DOT Sequence (B3JH AKEX). The date code is only on one side... you'll need to pull the set of duals to see the date code.
BruceMc - Thanks for the information. Now we'll, many of us at least, be waiting to find out who gets it done and reports back. Do you think the replacement also includes mounting and balancing?
