pnichols
Feb 02, 2014Explorer II
By the way, regarding pressures in your new M&S2 tires: The door sticker in our Ford E450 Itasca (Winnebago) Class C motorhome specifies 80 PSI in the rear tires and 65 PSI in the front tires ... NOT 80 PSI all around.
My M&S2 tires really ride smoother than the original M&S stock tires because at the time of replacement I went to a slightly taller size that puts more of an air column between the rim and the road surface: 215/85R16 ... which is actually a larger overall diameter tire than the stock 225/75R16 tires.
