Altern
Nov 20, 2013Explorer
XZA2 Energy tires are load range J which means a stiffer sidewall. (more plys) which could result in a slightly more harsh ride.
You must decide to keep the same or go for a bit softer ride with a load range H tire which you will find on most MH's.
You aren't going to wear out or overload either type like a trucker might - so buy the best riding tire.
And IMO just because someone else has a specific tire on his coach doesn't mean yours will ride the same if you change to his type tire.
Good luck
Good luck
38,769 PostsLatest Activity: Mar 31, 2026
