Found another issue last night while in AL. Temps dropped to low 50’s so I sparked up the furnaces. Thankfully everything worked fine until…. the back was getting too hot so I lowered the temperature and went to bed. A few hours later nature called and I walked into the back bathroom and it was like a sauna, over 80 degrees! I went and turned off the rear furnace. About 3 AM nature called again and the back furnace was STILL running. I went up front to the main control panel and it was quite chilly. Then the lightbulb lit. I turned off the FRONT furnace and the BACK furnace shut off!! I turned on the BACK furnace and the FRONT furnace came on!! So, something is either mis-wired or the control is mis-programmed.
On top of that, after two leveling jack repairs it now fails to level successfully. One or both rear jacks won’t ground. I give up until we get to our permanent residence at Palm Creek in Casa Grande, AZ and have the mobile tech make a house call.
