jplante4
Dec 04, 2014Explorer II
shelbylen wrote:
He did say last summer that the valve to turn the heater and AC was not working. So to turn the Ac on from fresh air while driving. Any ideas what that would be? If it's like a car, I know their is a little plastic piece that breaks. Usually they are in the heater core though on cars.
I had the same issue with the heater valve on my Monterey (Chevy chassis). Mine has the vacuum controls and a cable for the heater valve. If yours has a vacuum controller, the most likely problem is a leaking vacuum hose. If you determine that it's the controller, they are similar to the Chevy pickups of that era and you could find one in a junk yard.
If the heater valve cable is broken, see this post on my fix.
linky
Also, check the pix of the heater panel on that post and see if yours looks the same.
