Hello Scott..
lived in your neck of the woods 30 yrs Poway....went to Glimas every weekend....
Any way...actually turned out good....its 100 degrees in Texas by 1100 so I have to do this between daylight 0700 and 1000. I clean,sand ,clean and mask....sometimes takes many hrs work to spray 30 min.Everything I painted was primed with epoxy.
I usually use PPG but its so high ,this time I tried SUMMIT RACING.....bought $1300.00 worth paint and Id say its every bit as good as PPG. The bottom is single stage Urethane....went on good , no tiger stripping, or popping. Not a lot of gloss however. The red is candy apple 2 stage which is really good paint. Covered real good and the clear is wonderful....and this paint you can do over and over with 5 min flash.... The silver is the most metallic Ive ever seen in a standard base...when the sun hits it its astounding.....same clear.
When all is ready, I get up at 0630,wait for daylight,get all my stuff ready and wait till temp is 72-78 , humidity is in 70s and there is never a wind....and do it....
Piece of cake.....LOL....
Side note.....after I retired from the navy I work at the Escondido Union School district as design graphic artist and illustrator....till prop 13......I hated the job anyway....LOL.
tom
