Sez_Hoo_
Jul 14, 2014Explorer
I'm a retired Coast Guard Chief Electrician. A melted wire nut is usually caused by it being loose. A loose connection will generate a lot of heat. I suggest cutting back the burnt wires and reconnect them with a new wire nut. If you have a clamp on amp meter, check your amp draw on both hot leads.
38,705 PostsLatest Activity: Jan 14, 2025
