Tyler0215
May 02, 2017Explorer
Brake lights and fuel tank selector start with the fuses. Then check the ground. Then the switch, Do the turn signals work on the rear? If so it's probably the switch.
J B Weld makes a product that may seal the gray water tank. You need to determine what the tank is made of and buy the correct J B Weld.
