dennislanier's avatar
dennislanier
New Sunseeker slideout
Just this past week I saw a new Sunseeker Class C with a huge slideout. Instead of 2 separate slideouts for bedroom and living area, the entire wall on the drivers side except for about 2 feet would slide out. Looks like a great idea. I don't know if this is a new innovation, but it is certainly new to me. Anyone have any experience with this type of slideout and whether it is something new in a Class C?
  • Class C Motorhome Floorplans
    3050S - Ford Chassis
    Wheel Base 220" (5.6 m)
    GVWR 14,500 lbs. (6,577 kg)
    GCWR 22,000 lbs. (9,979 kg)
    Fuel Capacity 55 gal. (208 L)
    Exterior Length 31' 11" (9.7 m)
    Exterior Height 11' 3" (3.4 m)
    Exterior Width 101" (2.6 m)
    Fresh Water Capacity 44 gal. (167 L)
    Gray Water Capacity 39 gal. (148 L)
    Black Water Capacity 39 gal. (148 L)
    Awning Size 18 ft. 0 in.
  • One of these days I'm going to stop at the dealer just to see the space in the 3050.
  • o
    tatest wrote:
    They've been doing 12-16 foot slides on C's for at least ten years, much longer than that would be fairly recent. Full wall slideouts on A gassers go back to 2006-2008, not counting Rexhall, which has been doing full wall, both sides, for a long time.
    Building a full wall slideout is a matter of making a raised floor frame strong enough to support the cantilevered load, and synchronizing enough slide rams to move it easily. 16-20 foot used to be the limit for a pair of the lighter slide mechanisms normally used for Cs.
    To gerrym51, yes, this was the 3050S.
    To tatest, I am sure this was at least 20 feet, because this was a 31-32 foot Class C and the slideout was the full wall except for maybe 2 feet total. It also had automatic levelers and an outside entertainment center. I wanted to talk to the owner but when I had the opportunity he was busy around the campsite so I didn't bother him. I am sure it was a new 2013 or 2014 year model. Very impressive unit at least from the outside.
  • They've been doing 12-16 foot slides on C's for at least ten years, much longer than that would be fairly recent. Full wall slideouts on A gassers go back to 2006-2008, not counting Rexhall, which has been doing full wall, both sides, for a long time.
