Congrats!!!!
Think about it like this. If you bought a 1994 Chevy Pickup truck what would you do to make it reliable? Probably a list like below, and I would do everything listed on the coach.
1) inspect and replace brake components as needed (stopping is much more important than going)
2) replace all fluids(oil, transmission fluid, brake fluid, rear end fluid, power steering fluid, radiator fluid)
3) do a complete tune up on the motor
4) inspect and replace tires as needed
5) have the dash AC serviced
6) replace suspension components as needed.
7) have the slide components inspected if you have slides.
Now, do everything related to the motor again on the generator.
Next, inspect the appliances, pay attention to the water heater. They are bad to rot out around the water connections on the back.
Have all the propane systems inspected and replace as needed.
Nothing really unique to your Bounder in specificity, the appliances are common between most RV's.
I hope this helps some.
Thanks, Jeremiah
