imderrickjed
Jul 26, 2013Explorer
Thanks for the advise. I will flush the brake fluid and replace the fronts. I will inspect the rears and replace if needed. Im still having problems finding an owners manual for this 81 Shasta motorhome. As for the valve thats leaking I think its for the fresh water. I took a garden hose and tried to fill the holding tank, but it poured out a tube under the RV rasing straight down. looks like there was a valve but the handle is missing now. Not sure where to get a gas cap because I dont know if I should refer to it as a E350 1 ton van or if the RV takes a different cap. Same for the sending unit. I have dual tanks, the back leaks and the front has a bad sending unit. I want to replace the back, but no idea what to order. Family outings at least for this year will be 10-15 miles from home and IL in mostly flat land. No hills for where we are going. Next year id like to take it for a real trip.
