McRvguy wrote:
djbroughton wrote:
powderman426 wrote:
10 volts??? You have a dead battery. check your converter and fuses.
Batteries are good. This one is a mystery, voltage doesn't seem to change whether water pump switch is on or off.
It wont if the controller which grounds out the pump and allows it to run is bad or has bad connections!!
So tomorrow when I get some daylight to work, I will have a closer look at the "Intellitec Latching Controller". Service manual seems to be at:
http://www.intellitec.com/index.php/products/Motor_Controls/Water_pump_controllers/Water_Pump_Control
I'm looking for a loose ground connection to the pump or other loose wires, right?
