Bordercollie
May 30, 2017Explorer
If you buy a used rig, try to buy one that is some three to five years old. The roof AC, fridge, fresh water pump and awning will have some 5 or more years of service life remaining before needing repairs/replacement. Tires, brakes and engine cooling system may need replacement/servicing. The 12 volt electrical system includes the converter/charger, one or two house/auxiliary batteries, a house battery disconnect switch/latching solenoid that must be in good condition to operate the electronic appliance controls, fresh water pump, furnace fan, alarms, and interior lighting. Battery(s) must be good/newish, and converter charger must be working properly to keep battery(s) charged when rig is plugged into shore power. You must periodically check electrolyte levels in battery(s) and add DISTILLED water to cover the plates as needed as well as keeping connections clean and tight. You should have brake fluid flushed and replaced to avoid brake fade. Have front flexible brake lines replaced, they can fail internally causing possible loss of steering control.
If you buy new, make sure everything works before signing sales contract and that all promises by salesmen etc., are written into the contract parts and labor. Don't buy an extended mechanical warranty package, they are expensive and full of loopholes.Expect that dealer service department fixes will take two weeks or more before you can take off on your first touring/camping adventure. Try to buy from a dealer with a good reputation for after sale service.
Take time to educate yourselves and pick the brand, length, and floor plan that suits your needs and desires. IMHO, you should buy a rig with a rear bedroom with RV queen bed having access on both sides. Kids can sleep in the overhead and on convertible sofa or dinette cushions. Kids will lose interest in motorhoming at some point. If you are going to share a motorhome, have clear agreements on paying for repairs and maintenance as well as usage schedules.
