fttang's avatar
fttang
newbie battery and electrical question
Hi all,
new to the forum, bought a 04 E350 to do a camper conversion.
so i am considering the electrical things now,
just got a norcold 740bb fridge that draws 3.75amp under 12v mode,
planning to get a roof AC unit, seems most of them draws around 10amp on 12v.
will not have microwave or water heater. but maybe a tv and some speakers.
for the battery i am considering 2 lifeline GPL-4CT, because they are under $300 a piece and 220 usable amp-hour seems about enough for me(24 hours of fridge running and 10 hours of AC, plus a few other things)
the website i am shopping with recommends powermax chargers,
the 45 amp model has:
14.6 Boost Mode Output
13.6 Normal Mode Output
13.2 Float (trickle) Mode Output
how does this set up look? any recommendation? i don't want spend too much on the batteries so $600 is pretty much the limit, the charger is $150 on the same website.
and for the charger, i've read that you are only supposed to use this kind of 4 stage charger on the agm batteries, is there a 12v version out there so i can charge the agm house battery when the van is running? there were a person in this post was using 12v to 110v converter to draw power from engine generator and power the 110v charger to charge the house battery, i am assuming he is doing that because 12v 4 stage battery charger does not exist?
how about generators? what size(watts) am i looking at(with charger, fridge, and roof AC working under 110v)? any recommendations?
