Since Winnebago and Itasca are both made by Winnebago, you'll find they have the same model numbers. So the Itasca Cambria 30C is the same as the Winnebago Aspect 30C. The only difference between them is fit-and-finish.
If the Cambria you were looking at seemed like a better version of the Aspect, you were probably comparing a Cambria with more optional equipment to an Aspect without.
Knowing this about them helps when you're looking for models to buy. If you search for Winnebago 30C, often the Itasca models will come with it, which is a good thing.
