wra wrote:
Not being there, I can not advise for sure, but your water tank may be full and the fill water is draining out the overflow. There may be valves near the input hose that need to be turned on and another off, in order for the water system to work from the hose. The valves would need to be reversed, when the water supply hose is not connected and you want to use the water pump to get water from the tank. When using the hose, your water pump should be turned off. When using water from the tank, your water pump should be on.
thanks to the both of you. I'll go lookng for some water valves somewhere...sounds like this is the issue. FYI, these drains underneath are NOT threaded.
