Hjartagold's avatar
Hjartagold
Newbie planning first purchase
Hi,
My wife and I are planning to purchase a Class A diesel in the next month, to use as a part-time liveaboard for work.
Given the potential sensitivity of this subject - and I certainly don't want to initiate any flame wars here - please PM me with your responses.
Our budget is somewhat limited, so are looking for something used, in the $30k-$60k range, with relatively low miles if possible.
Given the number of manufacturers out there (it's mind-boggling), it's difficult to know what brands are more reliable than others, and which are known for having a better build quality.
We do want to be able to tow another vehicle (trailered).
We were considering a 5th wheel, but realized that with two 160 lb dogs, that carrying them in the back of a RAM 3500 Quad Cab was not going to work well (only one would fit in the back seat at a time), and so the next logical choice was the Class A.
I have noticed that the longer the motorhome, the higher the price, but I have no idea what brands I should be looking at, and which I should avoid.
I should also add that I may need to use it through a midwest winter as well, so it should be able to keep me comfortable during potential ice storms.
I would appreciate any input the members here might have.
Thank you in advance!
  • Don't know your situation or needs, but could a travel trailer work for you? You could tow it with a 3/4 or 1 ton van. Plenty of room in a van for the dogs. The van/TT set-up would save some money. Used fleet vans are readily available and affordable. They make good tow vehicles.
  • Hi,
    Definitely look for a unit with aquahot. If you can find one without a slide that would be good, too. Operating a slide in the cold may not be wise. Getting it out at -30 works ok--but the next morning bringing it back in may be a problem.
    Buy the smallest rv that will meet your needs. Why? Because it is a smaller area to heat. Do not rule out a class C. They come as large as 35 feet and the price is a lot cheaper.
    Make sure chassis parts are available.
    Look for water damage. Look harder for water damage. Look even harder for water damage.
  • Newmar is one of the very few who will give the R ratings on insulation. Newmar was also the first to come out with production slides on their coaches in 1990 so you will find a slide on older coaches. Winter is not an easy item in even the best of coaches. If you get an Aqua-Hot heating system you will be ahead on keeping warm. Good Luck.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Even if you spend full time on this from Branson, you'll be lucky to find the right DP in the next 30 days with your requirements. Other than Alfa I would not worry about the brand as each make entry level MHs and many make high end MHs. At that old and winter use you need high end. Even at $60K you'll be in the 95-98 years with maybe one slide. I would not worry about floor plan as in those years they are all about the same if they are front entry. You need double pain windows, a 10K hitch, 40', a Onan quite diesel generator, and AquaHot if possible. Good luck as in a year you'll probably be trading which costs $$$$ if you rush into this.
  • Welcome to the forum.
    I would start by looking at all different brands. Check online, dealers lots and private sales.
    Find a floor plan that works for you. Also, condition is very important.
    Start looking, there's something that will fit your budget and situation. I'm sure you're excited but, don't be in a big hurry to buy.
    Don't hesitate to ask questions on the forum, there is a lot of info available.
    Good luck, enjoy your search.
  • With those perimeters, you're probably limited to big, high quality rigs built in the early to mid 1990's. So, for comparison look at Holiday Rambler Imperial, Scepter or Navigators in the 42 to 45 foot length. They are all diesel powered and well insulated for winter use. Once you've narrowed down which features to want and those you can live without, check out the sold units listed in the on-line web site for the consignment lot, PPL in Texas. That will give you some idea what your money will buy. There are many, many good brands that will have similar features, such as Newmar.
  • There are a lot of parks that don't take one dog at that weight good luck with two.
